メインコンテンツにスキップ
ヘルプ
Dell Dimension 4600 Video Card Replacement
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
How to correctly replace the Video Card from Dell Dimension 4600.
  • 作成者: Arvind
  • 所要時間: 5 - 10 分
  • 難易度: 簡単
Use this guide to replace the video card in your computer.
セクション
ツール
手順 1 Video Card  ¶
Lay the computer flat so that you are looking down on all of the components.
手順 1 Video Card  ¶
  • Lay the computer flat so that you are looking down on all of the components.
手順 2  ¶
Locate the Video Card and the screw attached to the Video Card as shown in the picture.
手順 2  ¶
  • Locate the Video Card and the screw attached to the Video Card as shown in the picture.
手順 3  ¶
Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
手順 3  ¶
  • Remove the 8.9 mm screw by using a Phillips #2 screw-driver.
手順 4  ¶
Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
手順 4  ¶
  • Push down on the green clip located by the bottom right corner of the video card while simultaneously pulling the card up with your other hand.
手順 5  ¶
Pull the remainder of the card up and out of it's slot.
手順 5  ¶
  • Pull the remainder of the card up and out of it's slot.
