メインコンテンツにスキップ
ヘルプ
Acer AL1916 Stand Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
This guide will show the user how to remove the stand.
  • 作成者: Keith
  • 所要時間: 5分
  • 難易度: 簡単
The stand supports the monitor from falling over.
ツール
関連部品
手順 1 Stand  ¶
Lay the monitor on a flat surface so that the back is facing up.
手順 1 Stand  ¶
  • Lay the monitor on a flat surface so that the back is facing up.
手順 2  ¶
Grab the hinge cover with both hands on either side of the stand. Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
手順 2  ¶
  • Grab the hinge cover with both hands on either side of the stand.
  • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
手順 3  ¶
Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor. Support the monitor while removing the screws to prevent the monitor from falling.
手順 3  ¶
  • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
  • Support the monitor while removing the screws to prevent the monitor from falling.
  • Lift up to detach the stand.
