メインコンテンツにスキップ
ヘルプ
iBook G4 12" 1.33 GHz Lower Case Replacement
Replacing the plastic bottom case.
セクション
ファイル
ツール
手順 1 Lower Case  ¶
Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
手順 1 Lower Case  ¶
  • Use a spudger or small flathead screwdriver to remove the three rubber feet from the lower case.
手順 2  ¶
Remove the three newly-revealed Phillips screws.
手順 2  ¶
  • Remove the three newly-revealed Phillips screws.
手順 3  ¶
Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
手順 3  ¶
  • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
手順 4  ¶
Remove the three hex screws using a T8 Torx screwdriver.
手順 4  ¶
  • Remove the three hex screws using a T8 Torx screwdriver.
  • The shorter screw is in the center of the computer.
手順 5  ¶
Remove the two 4.5 mm Phillips screws on either sides of the battery contacts.
手順 5  ¶
  • Remove the two 4.5 mm Phillips screws on either sides of the battery contacts.
手順 6  ¶
Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
手順 6  ¶
  • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
  • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
手順 7  ¶
There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
手順 7  ¶
  • There is a slot on the wall of the battery compartment that locks the lower case in place. Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
手順 8  ¶
Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
手順 8  ¶
  • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case. Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
手順 9  ¶
Continue to run the spudger around the front right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
手順 9  ¶
  • Continue to run the spudger around the front right corner. There are two tabs on the port side of the computer, one near the front corner and one near the sound-out port.
手順 10  ¶
There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
手順 10  ¶
  • There are three tabs over the optical drive that must be released before the lower case can come off. Slide the spudger into the lower case above the optical drive and run it toward the back of the computer until you hear three distinct clicks.
手順 11  ¶
The front and sides of the lower case are now free.
手順 11  ¶
  • The front and sides of the lower case are now free.
  • Turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free.
  • It may be helpful to jiggle the case up and down.
手順 12  ¶
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
手順 12  ¶
  • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
手順 13  ¶
画像がありません
手順 13  ¶
  • Have patience and follow the directions, the end result is up to you. In my case it worked. But I was a Technician TRW Automotive. and worked on Air Bag modules that was returned from customer's that needed them analyzed. I just retired after 26 years.
