メインコンテンツにスキップ
ヘルプ
HTC Maple 100 Back Panel Replacement
続きが抜けています
続きが抜けています
このガイドはどのようにしてプロセスを始めるかの情報が抜けています。必要条件ガイドを作成しましょう!
Remove the back panel
Remove 4 Torx screws and 2 #00 Philps
手順 1 Back Panel  ¶
Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
手順 1 Back Panel  ¶
  • Remove the four 4.9mm T6 Torx screws that secure the back panel to the rest of the phone
手順 2  ¶
Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
手順 2  ¶
  • Remove the two 4.3mm #00 Phillips screws that secure the back panel to the rest of the phone
手順 3  ¶
Use the plastic opening tool to pry the clips off Insert the plastic opening tool along the seams at different points to it pry up This may require a bit of force. The USB port cover may fall off in this step.
手順 3  ¶
  • Use the plastic opening tool to pry the clips off
  • Insert the plastic opening tool along the seams at different points to it pry up
  • This may require a bit of force. The USB port cover may fall off in this step.
