ヘルプ
Mac mini Mid 2011 Speaker Replacement
Replace a blown-out speaker.
Use this guide to replace your mini's speaker. Replacing the speaker requires removal of the logic board.
セクション
ツール
手順 1 Speaker  ¶
Remove the following two screws securing the speaker to the logic board assembly:
手順 1 Speaker  ¶
  • Remove the following two screws securing the speaker to the logic board assembly:
  • One 3.5 mm T6 Torx screw
  • One 3.7 mm T6 Torx screw
手順 2  ¶
Lift but do not remove the speaker assembly, as it still remains connected to the logic board via the speaker connector. Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
手順 2  ¶
  • Lift but do not remove the speaker assembly, as it still remains connected to the logic board via the speaker connector.
  • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
  • Lift and remove the speaker away from the logic board.
