メインコンテンツにスキップ
ヘルプ
MacBook Air 13" Mid 2011 Lower Case Replacement
Replace the lower case on your MacBook Air 13" Mid 2011.
Use this guide to replace a damaged lower case.
手順 1 Lower Case  ¶
Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
手順 1 Lower Case  ¶
  • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
  • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
  • Two 9 mm screws
  • Eight 2.6 mm screws
手順 2  ¶
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
手順 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
