メインコンテンツにスキップ
ヘルプ
MacBook Air 11" Mid 2011 Heat Sink Replacement
Replace the heat sink on your Mid 2011 MacBook Air 11".
  • 作成者: Walter Galan
  • 所要時間: 20 - 40 分
  • 難易度: 普通
Use this guide to replace a damaged heat sink or to reapply thermal paste.
セクション
ツール
手順 1 Heat Sink  ¶
Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
手順 1 Heat Sink  ¶
  • Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
手順 2  ¶
If the heat sink seems to be stuck to the logic board after removing all four screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
手順 2  ¶
  • If the heat sink seems to be stuck to the logic board after removing all four screws, use a spudger to carefully separate the heat sink from the faces of the CPU and GPU.
  • Remove the heat sink from the logic board.
  • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
