メインコンテンツにスキップ
ヘルプ
Nexus 10 Front Facing Camera Replacement
より良い紹介部分
より良い紹介部分
この紹介部分を完成し編集することでこのガイドを改良する
Replace the front-facing camera of the Nexus 10.
手順 1 Front-Facing Camera  ¶
Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back. Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back. Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
  • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
手順 2  ¶
Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display. Pull the the plastic backing off the display assembly using your hands. Do not do this step with only your hands. You will require a significant amount of force to separate the device.
手順 2  ¶
  • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
  • Pull the the plastic backing off the display assembly using your hands.
  • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
手順 3  ¶
Lift latch on front-facing camera connector. Pull the connector toward the top of the device and remove the front-facing camera. Pull the connector toward the top of the device and remove the front-facing camera.
手順 3  ¶
  • Lift latch on front-facing camera connector.
  • Pull the connector toward the top of the device and remove the front-facing camera.
