メインコンテンツにスキップ
ヘルプ
Nikon D610 Outer Case Replacement
This guide will show you how to properly remove the outside case of the Nikon D610.
  • 作成者: Daniel Eagan
  • 所要時間: 25 - 45 分
  • 難易度: 普通
This guide will help you to get to the internal components of the camera.
セクション
ツール
手順 1 Outer Case  ¶
After removal of the battery. Pull the battery compartment door away from the lens.
手順 1 Outer Case  ¶
  • After removal of the battery. Pull the battery compartment door away from the lens.
  • There are eleven Philips head screws that hold the bottom cover on, including a few inside the battery compartment.
  • Remove all the screws and the bottom face should pop off easily.
手順 2  ¶
Then next step is removing the seven Philips #00 screws that hold the rear face plate on. There are screws hidden in three separate spots. One is under the rubber doors on the left side of the camera. the next one at the eye hole.
手順 2  ¶
  • Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
  • There are screws hidden in three separate spots.
  • One is under the rubber doors on the left side of the camera. the next one at the eye hole.
  • The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
  • Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
手順 3  ¶
The rear face plate will include the LCD display it separates from the body of the camera with a small tug. Do not pull to hard otherwise you risk breaking the ribbon wire that connects the controls and the screen.
手順 3  ¶
  • The rear face plate will include the LCD display it separates from the body of the camera with a small tug.
  • Do not pull to hard otherwise you risk breaking the ribbon wire that connects the controls and the screen.
  • Once there is enough space it will be possible to gently pull the ribbon cable out of their ports.
手順 4  ¶
The next piece to come off is the front plate and the red grip. The front plate is held on by 2 Philips #00 screws on the front and two more beneath the flash bulb.
手順 4  ¶
  • The next piece to come off is the front plate and the red grip.
  • The front plate is held on by 2 Philips #00 screws on the front and two more beneath the flash bulb.
  • Remove the two Phillips #00 screws holding on the grip and it slides off easily.
  • After removing the screws the face plate comes off by pulling it straight off to avoid damage.
手順 5  ¶
It is now possible to  remove the last three Philips #00 screws that are hidden under the memory card slot door. The screws come out and the cover comes straight off.
手順 5  ¶
  • It is now possible to remove the last three Philips #00 screws that are hidden under the memory card slot door.
  • The screws come out and the cover comes straight off.
  • The last cover plate is the top. The top is held on by two screws located just beneath the rim of the cover.
  • The top should be pulled off very slowly. There are several electronic components that connect between the body and the top.
  • There are three wires that need to be disconnected.
