メインコンテンツにスキップ
ヘルプ
iPhone SE Teardown
分解
分解
分解とはdeviceの内部構造を見て確認することです。解体の手引きとして使う事はできません。
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
iPhone mini? iPhone 5se? 5s Plus? After a rather long rumor cycle, we finally have our hands on the new iPhone SE. Billed as a 5s with better specs, we're excited to see the perfect union of existing Apple tech in a new body. Kinda like Taco Bell—same ingredients, new menu item. Let's open it up and spill the beans!
Want to be the first to see inside the latest gadgets? Follow us on Facebook, Instagram, or Twitter for the latest news from the repair world.
手順 1 iPhone SE Teardown  ¶
Out with the old, and in with the new—hardware, that is. Here's the skinny on what's hiding behind that oh-so-familiar face: Apple A9 processor with embedded M9 motion coprocessor
  • Out with the old, and in with the new—hardware, that is. Here's the skinny on what's hiding behind that oh-so-familiar face:
  • Apple A9 processor with embedded M9 motion coprocessor
  • 16 or 64 GB of storage
  • 4-inch, 1136 x 640 pixels (326 ppi) Retina display
  • 12 MP iSight camera supporting 4K video recording with 1.22 µ pixels, and a 1.2 MP ƒ/2.4 FaceTime HD camera
  • 802.11a/b/g/n/ac Wi‑Fi + Bluetooth 4.2 + NFC + 19-band LTE
  • Touch ID sensor supporting user authentication and Apple Pay
手順 2  ¶
Shifting our attention to the rose gold rear case, we spot the model number— A1662, never before seen in the wild. Colors notwithstanding, in a side-by-side comparison, the SE is nearly indistinguishable from its predecessor. We're not surprised. While the SE represents a substantial performance boost over the 5s, they have the same display and Touch ID sensor, and identical physical dimensions.
手順 2  ¶
  • Shifting our attention to the rose gold rear case, we spot the model number— A1662, never before seen in the wild.
  • Colors notwithstanding, in a side-by-side comparison, the SE is nearly indistinguishable from its predecessor.
  • We're not surprised. While the SE represents a substantial performance boost over the 5s, they have the same display and Touch ID sensor, and identical physical dimensions.
  • One new feature we can spot is the matte chamfered edges around the display.
手順 3  ¶
Now for the step we don't like. Pentalobes: a five-pointed reminder that Apple doesn't really want you opening up your device. Still, these pentalobes are totally cute and come in a matching rose gold. Setting the pretty pink screws aside, we iSclack the top off—and there's no pesky, color-matching display adhesive in sight. Compared to Apple's S-series flagships, this opening procedure is a snap.
手順 3  ¶
  • Now for the step we don't like. Pentalobes: a five-pointed reminder that Apple doesn't really want you opening up your device.
  • Still, these pentalobes are totally cute and come in a matching rose gold.
  • Setting the pretty pink screws aside, we iSclack the top off—and there's no pesky, color-matching display adhesive in sight. Compared to Apple's S-series flagships, this opening procedure is a snap.
  • We had speculated that the display gasketing in the 6s and 6s Plus was added for water resistance or structural reinforcement supporting 3D Touch. Its absence from this model and some preliminary tests suggests it's the latter.
手順 4  ¶
Just like in the iPhone 5s, lurking beneath the display of the SE we find the familiar Touch ID cable booby trap. For those not in the know, this cable adds a small element of danger to disassembly, as pulling up the display  too far without first removing the bracket and disconnecting the cable could cause accidental damage to the cable.
手順 4  ¶
  • Just like in the iPhone 5s, lurking beneath the display of the SE we find the familiar Touch ID cable booby trap.
  • For those not in the know, this cable adds a small element of danger to disassembly, as pulling up the display too far without first removing the bracket and disconnecting the cable could cause accidental damage to the cable.
  • We're itching to do some comparisons and parts testing—but, safety first. Let's disconnect that battery!
手順 5  ¶
Off pops the display assembly! A side-by-side comparison of displays out of the 5s (left) and SE (right) reveals... they're pretty much identical!
手順 5  ¶
  • Off pops the display assembly!
  • A side-by-side comparison of displays out of the 5s (left) and SE (right) reveals... they're pretty much identical!
  • The similarities are more than skin deep. After a little testing, we found the 5s display is plug-and-play in the SE—fitment, connectors, and functionality are the same. It fires right up. That means replacement parts and guides are already available!
手順 6  ¶
No need to repeat the mistakes of the past—we've mastered these handy battery tabs! The Li-ion battery in the iPhone SE comes in at 3.82 V, 6.21 Whr, and 1624 mAh. This offers a minor (but notable) capacity increase from the 1560 mAh cell in the 5s. Though it's not quite as capacious as the 1715 mAh cell found in the larger (and more power-hungry) iPhone 6s, Apple states this battery will provide up to 10 days of standby, 14 hours of talk time, and 13 hours of video playback.
手順 6  ¶
  • No need to repeat the mistakes of the past—we've mastered these handy battery tabs!
  • The Li-ion battery in the iPhone SE comes in at 3.82 V, 6.21 Whr, and 1624 mAh. This offers a minor (but notable) capacity increase from the 1560 mAh cell in the 5s.
  • Though it's not quite as capacious as the 1715 mAh cell found in the larger (and more power-hungry) iPhone 6s, Apple states this battery will provide up to 10 days of standby, 14 hours of talk time, and 13 hours of video playback.
  • Despite the apparently interchangeable displays, the SE's battery connector differs from that of the 5s. So, no chance to supercharge your old 5s, unfortunately.
手順 7  ¶
Next up, we pluck the upgraded rear-facing camera from its berth. While it looks pretty similar to the one in the 5s (left), the SE's camera (right) has far fewer pins on its connector.
手順 7  ¶
  • Next up, we pluck the upgraded rear-facing camera from its berth.
  • While it looks pretty similar to the one in the 5s (left), the SE's camera (right) has far fewer pins on its connector.
  • Do you think those extra megapixels ever get stuck in connector traffic?
  • The SE's iSight camera gets a resolution bump up to 12 MP, but a decrease in pixel pitch down to 1.22µm from the 1.5µm pitch in the 5s.
  • Since these are the exact same specs as the main camera in the iPhone 6s, we'd hoped the cameras might be interchangeable—but alas, our hopes of creating a complete Apple Frankenphone might be overreaching.
手順 8  ¶
We interrupt this teardown to bring you: more cowbell teardown! Our friends at Creative Electron have been getting their teardown on, X-ray style! We have for your enjoyment, three generations of iPhone 5 configurations.
手順 8  ¶
  • We interrupt this teardown to bring you: more cowbell teardown!
  • Our friends at Creative Electron have been getting their teardown on, X-ray style!
  • We have for your enjoyment, three generations of iPhone 5 configurations.
  • Really, the only obvious change is the addition of the bi-metal Apple logo.
  • That, and the addition of the Touch ID cable between the 5 and 5s (unfortunate placement still intact in the SE, too).
手順 9  ¶
Out speaker assembly, out vibrator, out SIM card and tray! Our testing confirms all these bits are interchangeable with their counterparts from the 5s—same form, same function. They bolt right up, and they work like a charm. Neat! Rose gold remains SE exclusive though, so you may need to upgrade for proper color coordination.
手順 9  ¶
  • Out speaker assembly, out vibrator, out SIM card and tray!
  • Our testing confirms all these bits are interchangeable with their counterparts from the 5s—same form, same function. They bolt right up, and they work like a charm. Neat!
  • Rose gold remains SE exclusive though, so you may need to upgrade for proper color coordination.
  • Also of note: waterproof seals! There be foamy silicone seals surrounding some—but, mysteriously, not all—of the logic board connections.
  • The front camera, volume controls, and rear camera connectors all get the fancy waterproofing treatment, while the LCD, digitizer, battery, and Lightning connector assembly all seemingly go without.
手順 10  ¶
We finally wrestle the Lightning connector assembly out of the 5s SE. It looks just like the 5s assembly, but the connectors are a smidge different; we couldn't get a 5s/SE swap to work out.
手順 10  ¶
  • We finally wrestle the Lightning connector assembly out of the 5s SE.
  • It looks just like the 5s assembly, but the connectors are a smidge different; we couldn't get a 5s/SE swap to work out.
  • Maybe a change to allow for USB 3.0? Speculation welcome.
手順 11  ¶
We pop the pesky rear connector off the logic board, and are free to scan the silicon fields of glory! Apple A9 APL1022 SoC + SK Hynix  2 GB LPDDR4 RAM as denoted by the markings H9KNNNBTUMUMR-NLH Qualcomm MDM9625M LTE Modem (as seen in iPhone 6/6 Plus)
手順 11  ¶
  • We pop the pesky rear connector off the logic board, and are free to scan the silicon fields of glory!
  • Apple A9 APL1022 SoC + SK Hynix 2 GB LPDDR4 RAM as denoted by the markings H9KNNNBTUMUMR-NLH
  • Qualcomm MDM9625M LTE Modem (as seen in iPhone 6/6 Plus)
  • Qualcomm WTR1625L RF Transceiver (as seen in iPhone 6/6 Plus)
  • Qualcomm QFE1100 Envelope Tracking IC (as seen in 6s/6s Plus, and 6/6 Plus)
  • Skyworks SKY77611 Quad-band Power Amplifier Module
  • We'd like to extend a huge thanks to our friends at Chipworks for helping us ID all of these chips! Check out their rad teardown of the iPhone SE for even more silicon goodness.
手順 12  ¶
There's even more silicon goodies on the reverse!
手順 12  ¶
  • There's even more silicon goodies on the reverse!
  • Toshiba THGBX5G7D2KLDXG 16 GB NAND Flash
  • 339S00134 (likely an iteration of the Universal Scientific Industrial 339S00043 Wi-Fi module)
  • Apple/Dialog 338S00170 Power Management IC
  • NXP 66V10 NFC Controller and 1610A3 Charging IC (as seen in iPhone 6s/6s Plus)
  • Skyworks SKY77826 Ultra low-band Power Amplifier Duplexer and SKY77357 2G/EDGE Power Amplifier Module (likely an iteration of SKY77336)
  • Apple/Cirrus Logic 338S00105 and 338S1285 Audio ICs (as seen in iPhone 6s/6s Plus)
  • Qualcomm WFR1620 Receive-only Transceiver (as seen in iPhone 6/6 Plus)
手順 13  ¶
Chip identification continued...
手順 13  ¶
  • Chip identification continued...
  • Avago ACPM-8020 Mid-band Power Amplifier Duplexer (as seen in iPhone 6 Plus)
  • Qorvo (TriQuint) TQF6410 Low-band Power Amplifier Duplexer (as seen in iPhone 6 Plus)
  • TDK EPCOS D5255 Diversity Receive Module
  • Qualcomm PM8019 PMIC (as seen in iPhone 6/6 Plus)
  • Qorvo (RF Micro Devices) RF5159 Antenna Switch Module (as seen in iPhone 6/6 Plus)
  • InvenSense EMS-A 6-axis Gyroscope and Accelerometer Combo
  • Broadcom BCM5976 Touchscreen Controller (first seen in iPhone 5)
手順 14  ¶
Whoa, now—looks like the button cable got a little more complicated since last time. The power button bracket now has some kind of contact cable doohickey, instead of a simple clip, potentially for grounding. With that, we're down to the rear case—time to wrap this teardown up!
手順 14  ¶
  • Whoa, now—looks like the button cable got a little more complicated since last time.
  • The power button bracket now has some kind of contact cable doohickey, instead of a simple clip, potentially for grounding.
  • With that, we're down to the rear case—time to wrap this teardown up!
手順 15  ¶
iPhone SE Repairability: 6 out of 10 (10 is easiest to repair) The display assembly is the first component out of the phone, simplifying screen replacements.
手順 15  ¶
  • iPhone SE Repairability: 6 out of 10 (10 is easiest to repair)
  • The display assembly is the first component out of the phone, simplifying screen replacements.
  • The battery is fairly easy to access, even though it's not technically "user replaceable."
  • The Touch ID cable could be easily ripped out of its socket if a user is not careful when opening the phone.
  • The iPhone SE still uses Pentalobe screws on the exterior, making it difficult to open without specialized tools.
  • The hardest part of any repair is knowing what to do. Thanks to the similarities to the 5s and our repair guides, repairs on the SE are already excellently documented—check it out.
