ヘルプ
iMac Intel 21.5" EMC 2428 AC Inlet Replacement
Replace the AC Inlet in your iMac Intel 21.5" EMC 2428.
Restore power to your iMac by replacing your AC inlet.
セクション
手順 1 AC Inlet  ¶
Remove the piece of clear tape covering the body of the AC inlet.
手順 1 AC Inlet  ¶
  • Remove the piece of clear tape covering the body of the AC inlet.
手順 2  ¶
Peel the three pieces of aluminum tape off the body of the AC inlet.
手順 2  ¶
  • Peel the three pieces of aluminum tape off the body of the AC inlet.
  • It is not necessary to completely remove the tape from the body of the iMac.
手順 3  ¶
Remove the three 9.3 mm T10 Torx screws securing the AC inlet to the outer case.
手順 3  ¶
  • Remove the three 9.3 mm T10 Torx screws securing the AC inlet to the outer case.
手順 4  ¶
Follow this step if your hard drive pressure wall is still installed.
手順 4  ¶
  • Follow this step if your hard drive pressure wall is still installed.
  • Pull the plastic wall installed just to the left of the hard drive away from the outer case.
  • Peel back the piece of tape securing the thermal sensor cables and remove the plastic wall from the iMac.
手順 5  ¶
Use a 5 mm nut driver to remove the 15.7 mm long standoff securing the AC inlet ground loop to the outer case.
手順 5  ¶
  • Use a 5 mm nut driver to remove the 15.7 mm long standoff securing the AC inlet ground loop to the outer case.
手順 6  ¶
De-route the AC inlet and ground cables from their retainers in the outer case and remove the AC inlet assembly from the iMac.
手順 6  ¶
  • De-route the AC inlet and ground cables from their retainers in the outer case and remove the AC inlet assembly from the iMac.
