メインコンテンツにスキップ
ヘルプ
MacBook Pro 15" Unibody Early 2011 Heat Sink Replacement
Replace your Early 2011 MacBook Pro 15" Unibody's heat sink.
  • 作成者: Walter Galan
  • 所要時間: 1 - 2 時間
  • 難易度: 難しい
Replacing the heat sink requires removal of the logic board and application of new thermal paste.
手順 1 Heat Sink  ¶
Lay the logic board down on a soft flat surface with the heat sink facing up.
手順 1 Heat Sink  ¶
  • Lay the logic board down on a soft flat surface with the heat sink facing up.
  • Remove the six #1 Phillips screws securing the heat sink to the logic board.
  • Keep track of the small springs housed under each screw.
手順 2  ¶
Remove the heat sink from the logic board.
手順 2  ¶
  • Remove the heat sink from the logic board.
  • If the heat sink appears to be stuck to the logic board after removing all six screws, it may be helpful to use a spudger to separate the two components.
  • If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
