メインコンテンツにスキップ
ヘルプ
MacBook Pro 15" Unibody Early 2011 Hard Drive/IR Sensor Cable Replacement
Replace the hard drive/IR sensor cable on your MacBook Pro 15" Unibody Early 2011.
The hard drive cable also contains the IR sensor/sleep indicator.
手順 1 Hard Drive/IR Sensor Cable  ¶
Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
  • Use the flat end of a spudger to pry the hard drive cable connector up off the logic board.
手順 2  ¶
Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
手順 2  ¶
  • Remove the following four screws securing the hard drive and IR sensor cable to the upper case:
  • Two 1.5 mm Phillips screws.
  • Two 4 mm Phillips screws.
手順 3  ¶
Slide the hard drive and IR sensor bracket away from the edge of the upper case. Carefully peel the hard drive and IR sensor cable from the upper case. Lift the hard drive and IR sensor assembly out of the upper case.
手順 3  ¶
  • Slide the hard drive and IR sensor bracket away from the edge of the upper case.
  • Carefully peel the hard drive and IR sensor cable from the upper case.
  • Lift the hard drive and IR sensor assembly out of the upper case.
手順 4  ¶
Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable. Use the tip of a spudger to flip the ZIF connector on the hard drive cable. Gently pull the sensor bracket cable out of the ZIF connector.
手順 4  ¶
  • Your replacement part may or may not come with the front (sensor) bracket. If it does not, you'll need to transfer it to your new cable.
  • Use the tip of a spudger to flip the ZIF connector on the hard drive cable.
  • Gently pull the sensor bracket cable out of the ZIF connector.
  • Use the flat end of a spudger to pry the hard drive cable up off the sensor bracket.
  • Remove the adhesive backing from your new hard drive cable, stick it onto the sensor bracket, and connect the sensor bracket cable.
