メインコンテンツにスキップ
ヘルプ
Nikon Coolpix E5700 Rear LCD Replacement
Access and remove the LCD screen in the back of the camera.
  • 作成者: Kyle Sitton
  • 所要時間: 10 - 15 分
  • 難易度: 簡単
This guide will walk you through the necessary steps to access and remove the LCD screen in the Nikon Coolpix E5700.
セクション
ツール
手順 1 Rear LCD  ¶
Remove two Phillips screws (3.4 mm) located on the left side of the screen.
手順 1 Rear LCD  ¶
  • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
手順 2  ¶
Remove two Phillips screws (3.4 mm) located on the right side of the screens. Remove two Phillips screws (3.4 mm) located on the right side of the screens.
手順 2  ¶
  • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
手順 3  ¶
Remove back plastic monitor cover. Remove back plastic monitor cover.
手順 3  ¶
  • Remove back plastic monitor cover.
手順 4  ¶
Remove the Phillips screw on the top right side of the screen.
手順 4  ¶
  • Remove the Phillips screw on the top right side of the screen.
手順 5  ¶
Carefully unplug the grey bundle of wires in the white housing.
手順 5  ¶
  • Carefully unplug the grey bundle of wires in the white housing.
手順 6  ¶
Carefully unplug the small pink and wires in the grey housing.
手順 6  ¶
  • Carefully unplug the small pink and wires in the grey housing.
手順 7  ¶
Remove the two Phillips screws on the left side of the screen.
手順 7  ¶
  • Remove the two Phillips screws on the left side of the screen.
手順 8  ¶
Remove the metal bar on the left side of the screen.
手順 8  ¶
  • Remove the metal bar on the left side of the screen.
  • Remove the screen from the front plastic housing.
