メインコンテンツにスキップ
ヘルプ
Canon PowerShot SD700 LCD screen Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
Installation and replacement of new LCD screen
  • 作成者: Emilio Rossi
  • 所要時間: 10 - 15 分
  • 難易度: 普通
Follow these steps to remove and install a new LCD screen.
セクション
ツール
手順 1 LCD screen  ¶
Remove the two screws that connect the LCD and backlight to the main body of the camera.
手順 1 LCD screen  ¶
  • Remove the two screws that connect the LCD and backlight to the main body of the camera.
手順 2  ¶
Gently pry the LCD and the backlight from the main body of the camera. Gently pry the LCD from the backlight. The thin ribbon cable is for the backlight.
手順 2  ¶
  • Gently pry the LCD and the backlight from the main body of the camera.
  • Gently pry the LCD from the backlight.
  • The thin ribbon cable is for the backlight.
  • The thick ribbon cable is for the LCD screen.
手順 3  ¶
Carefully lift the ZIF connector that covers the thick ribbon cable.
手順 3  ¶
  • Carefully lift the ZIF connector that covers the thick ribbon cable.
  • This ZIF connector is fragile. Use caution when lifting it from its down position.
  • Insert the new LCD and reassemble the camera.
