メインコンテンツにスキップ
ヘルプ
HTC Touch Speaker Replacement
箇条書き!
箇条書き!
マークアップやブレットの色や形を変えてコーディネートしてみるとこのガイドをより見やすくできます。
The goal of this guide is to instruct people how to properly replace the speaker for the HTC Touch 6900.
  • 作成者: Andrew Brooks
  • 所要時間: 15 - 30 分
  • 難易度: 普通
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
手順 1 Speaker  ¶
Remove the back panel by sliding up.
手順 1 Speaker  ¶
  • Remove the back panel by sliding up.
手順 2  ¶
Remove the battery.
手順 2  ¶
  • Remove the battery.
手順 3  ¶
Remove the 2 torx-head screws located at the top corners of the phone using the T5 Torx Screwdriver.
手順 3  ¶
  • Remove the 2 torx-head screws located at the top corners of the phone using the T5 Torx Screwdriver.
手順 4  ¶
Remove the plastic speaker casing above the battery slot.
手順 4  ¶
  • Remove the plastic speaker casing above the battery slot.
手順 5  ¶
Use the plastic opening tool to remove the speaker.
手順 5  ¶
  • Use the plastic opening tool to remove the speaker.
