メインコンテンツにスキップ
ヘルプ
PowerBook G4 Aluminum 12" 1-1.5 GHz Keyboard Replacement
  • 作成者: iRobot
  • 所要時間: 20分 - 1時間
  • 難易度: 普通
This guide shows the hidden screws you must remove when replacing the keyboard.
セクション
ファイル
手順 1 Keyboard  ¶
On the keyboard, remove the F1, F2, F11, and F12 keys.
手順 1 Keyboard  ¶
  • On the keyboard, remove the F1, F2, F11, and F12 keys.
  • This is scary - take a deep breath before continuing. Place your index finger under the upper left corner of the key and lift up until you hear a click. Then, transfer your finger to the left edge of the key and lift up to pull the key off.
  • You're freeing the two tabs on the left of the key from the two small holes in the plastic scissors mechanism.
  • When replacing the keys in the keyboard, place the key directly over the slot where it will go and press down until you hear the key click into place.
手順 2  ¶
Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
手順 2  ¶
  • Use your fingernail or a small flathead screwdriver to peel up the gray stickers covering each of the screws.
手順 3  ¶
Remove the two short Phillips screws.
手順 3  ¶
  • Remove the two short Phillips screws.
手順 4  ¶
Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
手順 4  ¶
  • Lift the keyboard by the 'esc' and 'eject' keys and gently lift up until the keyboard is vertical.
手順 5  ¶
Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
手順 5  ¶
  • Grasp the keyboard connector ribbon near the connector and disconnect it from the logic board.
