メインコンテンツにスキップ
ヘルプ
iPad 2 Wi-Fi EMC 2415 Rear Facing Camera Replacement
Replace the rear facing camera in your iPad 2 Wi-Fi EMC 2415.
Use this guide to replace a broken rear facing camera.
手順 1 Rear Facing Camera  ¶
Carefully peel the rubber cover off the metal camera retainer and remove it from the iPad 2.
  • Carefully peel the rubber cover off the metal camera retainer and remove it from the iPad 2.
手順 2  ¶
Remove the following two screws: One 3.3 mm Phillips screw One 2.1 mm Phillips screw
手順 2  ¶
  • Remove the following two screws:
  • One 3.3 mm Phillips screw
  • One 2.1 mm Phillips screw
  • Lift the metal retainer clip straight up from its recess in the rear panel.
  • Be sure the small thermal pad is attached to the metal retaining clip as seen in the third picture when replacing the rear facing camera.
手順 3  ¶
Use a plastic opening tool to pry the rear camera connector up from its socket on the control board. Remove the rear facing camera.
手順 3  ¶
  • Use a plastic opening tool to pry the rear camera connector up from its socket on the control board.
  • Remove the rear facing camera.
