メインコンテンツにスキップ
ヘルプ
iMac Intel 24" EMC 2111 Display Assembly Replacement
Remove the display assembly on your iMac Intel 24" EMC 2111.
Use this guide to remove the display assembly.
セクション
ツール
手順 1 Display Assembly  ¶
Peel the two highlighted EMI shield tabs off the frame of the LCD. Peel the two highlighted EMI shield tabs off the frame of the LCD.
  • Peel the two highlighted EMI shield tabs off the frame of the LCD.
手順 2  ¶
Remove the two T6 Torx screws securing the display data cable to the logic board.
手順 2  ¶
  • Remove the two T6 Torx screws securing the display data cable to the logic board.
手順 3  ¶
Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
手順 3  ¶
  • Pull the black plastic tab attached to the display data cable connector to disconnect it from the logic board.
手順 4  ¶
Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board. De-route the inverter cable from its location next to the CPU fan.
手順 4  ¶
  • Use your fingertips to pull both sides of the wide inverter cable connector out of its socket on the logic board.
  • De-route the inverter cable from its location next to the CPU fan.
手順 5  ¶
Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
手順 5  ¶
  • Before attempting this step, we recommend laying your iMac stand-side down on a table to avoid the display falling down.
  • Remove the eight T8 Torx screws securing the display assembly to the rear case.
  • It is helpful to use a thin magnetized screwdriver to remove these screws.
手順 6  ¶
Remove the display assembly from the iMac.
手順 6  ¶
  • Remove the display assembly from the iMac.
