メインコンテンツにスキップ
ヘルプ
LG G4 Motherboard Replacement
If your LG G4 is not working properly and you have concluded that the issue is in the mother board. If you need to replace it, this guide will walk you through it.
  • 作成者: carolinavind
  • 所要時間: 10分
  • 難易度: 普通
This guide will show you how to replace the Motherboard.
手順 1 Motherboard  ¶
Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool: Front-facing camera connector.
手順 1 Motherboard  ¶
  • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
  • Front-facing camera connector.
  • Rear-facing camera connector.
  • Digitizer connector.
  • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
手順 2  ¶
Remove the motherboard by lifting it up using the plastic opening tool and your fingers . Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
手順 2  ¶
  • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
