メインコンテンツにスキップ
ヘルプ
MacBook Pro 15" Core Duo Model A1150 Display Assembly Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
Use this guide to replace the display assembly.
  • 作成者: iRobot
  • 所要時間: 45分 - 3時間
  • 難易度: 普通
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
セクション
ツール
手順 1 Display Assembly  ¶
Disconnect the two antenna cables attached to the Airport Extreme card.
  • Disconnect the two antenna cables attached to the Airport Extreme card.
  • The white antenna cable connects to the left side of the Airport Extreme card.
手順 2  ¶
Deroute the Airport antenna cables from their channel in the left speaker.
手順 2  ¶
  • Deroute the Airport antenna cables from their channel in the left speaker.
手順 3  ¶
Disconnect the iSight, inverter, and left fan cables from the logic board by gently pulling in the direction of each cable.
手順 3  ¶
  • Disconnect the iSight, inverter, and left fan cables from the logic board by gently pulling in the direction of each cable.
手順 4  ¶
Disconnect the display data cable from the logic board.
手順 4  ¶
  • Disconnect the display data cable from the logic board.
手順 5  ¶
Remove the silver T6 Torx screw securing the ground loop on the display data cable to the casing.
手順 5  ¶
  • Remove the silver T6 Torx screw securing the ground loop on the display data cable to the casing.
手順 6  ¶
Support the display with one hand while removing the following 3 screws:
手順 6  ¶
  • Support the display with one hand while removing the following 3 screws:
  • Two 9.5 mm silver T6 Torx screws with threads on only part of the shaft on the inside of the display hinges.
  • One 9.5 mm silver T6 Torx screw with threads on the entire shaft on the outside of the left hinge.
手順 7  ¶
Grasp the display assembly on both sides and lift it up and out of the computer.
手順 7  ¶
  • Grasp the display assembly on both sides and lift it up and out of the computer.
