メインコンテンツにスキップ
ヘルプ
Disassembling Canon PowerShot SD1100 IS Front and Rear Cover
This guide will show how to remove the front and rear cover of the Canon PowerShot SD1100 IS.
Use this guide to remove the front and rear cover of the Canon PowerShot SD1100 IS.
手順 1 Front and Rear Cover  ¶
Remove wrist strap and battery. Remove wrist strap and battery.
  • Remove wrist strap and battery.
手順 2  ¶
Remove 2 screws from each side of the camera (4 total, 0.102 in). Remove 2 screws from the bottom on the camera (0.138 in). Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
手順 2  ¶
  • Remove 2 screws from each side of the camera (4 total, 0.102 in).
  • Remove 2 screws from the bottom on the camera (0.138 in).
  • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
手順 3  ¶
Gently pull off the front cover. The plate on the side should come off. Gently pull off the back cover.
手順 3  ¶
  • Gently pull off the front cover.
  • The plate on the side should come off.
  • Gently pull off the back cover.
手順 4  ¶
The cases should now be removed.
手順 4  ¶
  • The cases should now be removed.
