メインコンテンツにスキップ
ヘルプ
MacBook Pro 15" Core Duo Model A1150 Upper Case Replacement
必要条件のみ
必要条件のみ
このガイドは他のガイドにとって唯一の必要条件であることに注意してください。
  • 作成者: iRobot
  • 難易度: 普通
Changing the top case will also give you a new trackpad.
セクション
手順 1 Upper Case  ¶
Remove the two Phillips screws in the battery compartment near the latch.
手順 1 Upper Case  ¶
  • Remove the two Phillips screws in the battery compartment near the latch.
手順 2  ¶
Remove the following 6 screws:
手順 2  ¶
  • Remove the following 6 screws:
  • Two 10 mm T6 Torx screws on either side of the RAM slot.
  • Four 14.5 mm Phillips screws along the hinge.
手順 3  ¶
Remove the four Phillips screws on the port side of the computer.
手順 3  ¶
  • Remove the four Phillips screws on the port side of the computer.
手順 4  ¶
Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
手順 4  ¶
  • Rotate the computer 90 degrees and remove the two Phillips screws from the rear of the computer.
手順 5  ¶
Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
手順 5  ¶
  • Rotate the computer 90 degrees again and remove the four Phillips screws from the side of the computer.
手順 6  ¶
Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
手順 6  ¶
  • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
  • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case. This stage can be quite tricky. Over the DVD reader are 4 tabs set back which pull out vertically.
  • Note that the two small tongues on the left hand front of the upper case may bend while you remove the upper case. When re-installing, you may need to bend them back to fit in the grooves in the lower case.
手順 7  ¶
Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
手順 7  ¶
  • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
  • Remove the upper case.
