メインコンテンツにスキップ
ヘルプ
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Display Data Cable Replacement
Replace a worn or broken display data cable in your PowerBook G4 Aluminum 17" 1.67 GHz (High-Res).
Use this guide to replace a worn-out or broken display data cable.
手順 1 Display Data Cable  ¶
If present, remove the strip of tape covering the display data cable connector.
  • If present, remove the strip of tape covering the display data cable connector.
手順 2  ¶
Disconnect the display data cable from the LCD.
手順 2  ¶
  • Disconnect the display data cable from the LCD.
手順 3  ¶
Display data cable remains.
手順 3  ¶
  • Display data cable remains.
