メインコンテンツにスキップ
ヘルプ
Samsung Galaxy S4 Display Assembly (No Frame) Replacement
メンバーによる寄稿ガイド
メンバーによる寄稿ガイド
私たちのコミュニティーの素晴らしいメンバーがこのガイドを作成しました。これはiFixitスタッフによって管理されていません。
Samsung Galaxy S4 Display Assembly, no Frame Replacement
  • 作成者: ZFix
  • 所要時間: 25 - 30 分
  • 難易度: 難しい
How to replace broken display assembly without middle frame.
手順 1 Display Assembly  ¶
Use a heat gun or hair dryer and warm the digitizer glass. If the glass is broken, put some scotch tape. Use an utility knife and make a room at upper side between the glass and the frame.
  • Use a heat gun or hair dryer and warm the digitizer glass.
  • If the glass is broken, put some scotch tape.
  • Use an utility knife and make a room at upper side between the glass and the frame.
  • Continue with the separating with a plastic tools (plastic spudger or something similar).
手順 2 Display Assembly  ¶
Be very careful with the menu buttons flex cable. Be very careful with the menu buttons flex cable.
  • Be very careful with the menu buttons flex cable.
手順 3 Middle Frame  ¶
Clean the frame from the old adhesive tape and install a new one. Preferably, use adhesive sticker which is made for the model.
手順 3 Middle Frame  ¶
  • Clean the frame from the old adhesive tape and install a new one.
  • Preferably, use adhesive sticker which is made for the model.
手順 4 Adhesive  ¶
When you install the new adhesive tape be careful, don't cover the holes for the front camera, light sensor, etc. Start with reassembling. Start with reassembling.
手順 4 Adhesive  ¶
  • When you install the new adhesive tape be careful, don't cover the holes for the front camera, light sensor, etc.
  • Start with reassembling.
手順 5 Reassembling  ¶
That's all.
手順 5 Reassembling  ¶
  • That's all.
  • Did you do it successfully?
