メインコンテンツにスキップ
ヘルプ
HP Mini 1000 Battery Replacement
Replace the battery in your HP Mini 1000.
This guide will show you how to replace the battery in your HP Mini 1000.
手順 1 Battery  ¶
With the case closed, place the Mini 1000 top-side down on a flat surface. Push both of the battery release latches toward each other.
手順 1 Battery  ¶
  • With the case closed, place the Mini 1000 top-side down on a flat surface.
  • Push both of the battery release latches toward each other.
手順 2  ¶
Lift the battery out of the Mini 1000 from the edge closest to the release latches.
手順 2  ¶
  • Lift the battery out of the Mini 1000 from the edge closest to the release latches.
