メインコンテンツにスキップ
ヘルプ
技術: How to Reuse Dry Nail Polish
An easy way to reuse dry nail polish without having the need to throw it away.
  • 作成者: Iridian Vaca
  • 所要時間: 5分
  • 難易度: 簡単
Have you ever thrown out nail polish because it has dried out? Many people don't know that dry nail polish can actually be saved. In a couple simple steps you can reuse dry nail polish without the need of buying new bottles.
手順 1 How to Reuse Dry Nail Polish  ¶
Find a clean workplace where you can easily clean up spills.
  • Find a clean workplace where you can easily clean up spills.
  • DO NOT USE ACETONE TO THIN THE NAIL POLISH. Acetone is a solvent for removing nail polish. It can make the nail polish work but, the end result is dull or lumpy nail polish.
  • You can use a few drops of 91% isopropyl alcohol or ethyl acetate as solvents for thinning nail polish.
手順 2  ¶
Open the bottle of dry nail polish setting the brush to the side. Open the bottle of nail polish thinner.
手順 2  ¶
  • Open the bottle of dry nail polish setting the brush to the side.
  • Open the bottle of nail polish thinner.
  • Squirt 2 drops of nail polish thinner into the dry nail polish.
  • Screw the top back onto the dry nail polish and roll the bottle between your hands to mix. Shaking the bottle can put air bubbles in the nail polish and ruin a manicure.
  • Be careful to not not spill any nail polish thinner.
手順 3  ¶
If the nail polish is still dry or thick repeat steps 2-3 until the nail polish is finally thinned. Do not apply too much nail polish thinner, this will result in watery nail polish.
手順 3  ¶
  • If the nail polish is still dry or thick repeat steps 2-3 until the nail polish is finally thinned.
  • Do not apply too much nail polish thinner, this will result in watery nail polish.
