ヘルプ
Replacing Strings on a Mandolin
Learn all you need to know to properly replace strings on your Gretsch New Yorker Mandolin.
  • 作成者: Drew
  • 所要時間: 15分
  • 難易度: 普通
This guide gives step-by-step instructions for replacing strings in the most appropriate manner, ensuring that you can do some seriously righteous jamming on your New Yorker!
手順 1 Mandolin Strings  ¶
Place the mandolin on a firm, level surface with adequate lighting.
  • Place the mandolin on a firm, level surface with adequate lighting.
手順 2  ¶
Loosen the tuning nob.
手順 2  ¶
  • Loosen the tuning nob.
  • Carefully remove the top end of string from the tuner in the mandolin head.
手順 3  ¶
Unhook the old string from the tail of the mandolin.
手順 3  ¶
  • Unhook the old string from the tail of the mandolin.
  • Remove the string from the bottom.
手順 4  ¶
Select a new string, and then insert the bottom end of it through the bridge at the tail.
手順 4  ¶
  • Select a new string, and then insert the bottom end of it through the bridge at the tail.
手順 5  ¶
Secure the string to the tail by looping it over the hook.
手順 5  ¶
  • Secure the string to the tail by looping it over the hook.
手順 6  ¶
Pulling the string taut, bring its top end across the nut and into the tuning peg.
手順 6  ¶
  • Pulling the string taut, bring its top end across the nut and into the tuning peg.
手順 7  ¶
Run the line through the tuning element at the head of the mandolin,  as pictured.  Be sure to pull the string away from the headstock.
手順 7  ¶
  • Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
手順 8  ¶
Pull the string down, towards the fretboard, and run the string underneath itself. Pull the string tight so that it wraps around the tuning peg.
手順 8  ¶
  • Pull the string down, towards the fretboard, and run the string underneath itself.
  • Pull the string tight so that it wraps around the tuning peg.
手順 9  ¶
Pinch the string over itself to create a knot.
手順 9  ¶
  • Pinch the string over itself to create a knot.
手順 10  ¶
Tighten the tuning nob until the desired tension is reached.
手順 10  ¶
  • Tighten the tuning nob until the desired tension is reached.
手順 11  ¶
Clip off any excess string.
手順 11  ¶
  • Clip off any excess string.
手順 12  ¶
Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
手順 12  ¶
  • Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
手順 13  ¶
Commence rocking on with your Gretsch New Yorker!
手順 13  ¶
  • Commence rocking on with your Gretsch New Yorker!
