メインコンテンツにスキップ
ヘルプ
Nikon Coolpix L18 Logic Board Replacement
間違いの指摘
間違いの指摘
このガイドは最適な校正が必要です。校正の注釈を付けたり訂正することにご協力ください。
手順の記述もれ
手順の記述もれ
申し訳ございませんがこのガイドは、いくつかの重要なステップが不足しています。
  • 作成者: Aaron
  • 所要時間: 15 - 20 分
  • 難易度: 難しい
In this guide, we will give you step-by-step instructions on how to remove the logic board so that it can be replaced or repaired.
セクション
手順 1 Logic Board  ¶
Remove the tape on the top of the logic board. Remove the tape on the top of the logic board.
手順 1 Logic Board  ¶
  • Remove the tape on the top of the logic board.
手順 2  ¶
Remove the 4 Phillips #00 screws holding the top of the logic board onto the camera frame.
手順 2  ¶
  • Remove the 4 Phillips #00 screws holding the top of the logic board onto the camera frame.
手順 3  ¶
Desolder the joint of the top and back of the logic board using a soldering iron and desoldering wick.
手順 3  ¶
  • Desolder the joint of the top and back of the logic board using a soldering iron and desoldering wick.
  • You will need to have soldering equipment to complete this step.
手順 4  ¶
Move the top of the logic board to the side, exposing the top of the frame.
手順 4  ¶
  • Move the top of the logic board to the side, exposing the top of the frame.
  • Desolder the two connections on the top right of the logic board using a soldering iron and desolering wick.
