メインコンテンツにスキップ
ヘルプ
Nokia 2610 Speaker Replacement
This guide will show you how to replace the speaker.
After you have successfully completed the faceplate and circuit board removal guide this guide will show you how to replace the speaker
セクション
手順 1 Speaker  ¶
Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone. Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker. Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker.
手順 1 Speaker  ¶
  • Using the plastic opening tool, gently pry the speaker out of its slot in the back cover of the phone.
  • Note: The easiest way to remove the speaker is to insert the plastic opening tool in the upper right corner of the speaker.
