メインコンテンツにスキップ
ヘルプ
Panasonic Lumix DMC-TZ5 AV port circuit board Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
This guide will tell you how to remove and replace the AV port circuit board in your Panasonic Lumix DMC-TZ5.
  • 作成者: Kevin Lufkin
  • 所要時間: 25分
  • 難易度: 普通
This is the circuit board that the AV chord attaches to for transferring images.
手順 1 AV port circuit board  ¶
Use the spudger to unclip the top ribbon cable from the circuit board.
  • Use the spudger to unclip the top ribbon cable from the circuit board.
手順 2  ¶
Remove the single 2mm screw in the bottom right corner of the circuit board
手順 2  ¶
  • Remove the single 2mm screw in the bottom right corner of the circuit board
手順 3  ¶
Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove. The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
手順 3  ¶
  • Gently slide the circuit board out away from the port connections. Pull it toward where the lens used to be. Some wiggling may be necessary to remove.
  • The circuit board is fitted into slots attached to the side of the camera. Do not angle upwards to remove.
手順 4  ¶
Take note of how the slots fit into the circuit board for easy replacement.
手順 4  ¶
  • Take note of how the slots fit into the circuit board for easy replacement.
