メインコンテンツにスキップ
ヘルプ
Panasonic Lumix DMC-TZ5 button board Replacement
This board contains the control buttons on the rear of the camera and the attachment from the top controls
  • 作成者: Ben Canfield
  • 所要時間: 15分
  • 難易度: 普通
セクション
ツール
手順 1 button board  ¶
Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip. Carefully remove the function switch cover. This unit snaps on and off.
手順 1 button board  ¶
  • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
  • Carefully remove the function switch cover. This unit snaps on and off.
手順 2  ¶
Carefully unsnap the front logic board from the rear logic board using a spudger.
手順 2  ¶
  • Carefully unsnap the front logic board from the rear logic board using a spudger.
手順 3  ¶
Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera. Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
手順 3  ¶
  • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
手順 4  ¶
Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger. This leaves you with the logic board and the top connection panel separate and free from the camera This leaves you with the logic board and the top connection panel separate and free from the camera
手順 4  ¶
  • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
  • This leaves you with the logic board and the top connection panel separate and free from the camera
