メインコンテンツにスキップ
ヘルプ
Xbox One Optical Drive Replacement
Use this guide to replace the optical drive in your Xbox One.
Stuck disk? Having trouble installing that new game, or loading up your Blu-ray copy of Con Air? Follow this guide to replace a broken optical drive in your Xbox One.
手順 1 Optical Drive  ¶
Disconnect the optical drive power and SATA data cables from the motherboard. Disconnect the optical drive power and SATA data cables from the motherboard.
  • Disconnect the optical drive power and SATA data cables from the motherboard.
手順 2  ¶
Remove the optical drive assembly from the Xbox.
手順 2  ¶
  • Remove the optical drive assembly from the Xbox.
手順 3  ¶
The optical drive tray is held onto the optical drive by two plastic clips. Push the clips outward and then slide the tray off the drive. Push the clips outward and then slide the tray off the drive.
手順 3  ¶
  • The optical drive tray is held onto the optical drive by two plastic clips.
  • Push the clips outward and then slide the tray off the drive.
手順 4  ¶
Remove the optical drive power and SATA data cables. Remove the optical drive power and SATA data cables.
手順 4  ¶
  • Remove the optical drive power and SATA data cables.
