メインコンテンツにスキップ
ヘルプ
Nintendo 2DS Battery Replacement
This guide details how to replace the battery on the Nintendo 2DS.
This guide illustrates how to remove the upper rear panel from the Nintendo 2DS to access the battery and other parts of the device.
手順 1 Battery  ¶
Remove the two Phillips screws securing the upper rear panel.
手順 1 Battery  ¶
  • Remove the two Phillips screws securing the upper rear panel.
  • The screws will not completely detach from the back panel.
手順 2  ¶
Hinge the upper rear panel upwards and outwards to remove it. Hinge the upper rear panel upwards and outwards to remove it.
手順 2  ¶
  • Hinge the upper rear panel upwards and outwards to remove it.
手順 3  ¶
Remove the battery from its housing by lifting it up from the side closest to the outside edge. Remove the battery from its housing by lifting it up from the side closest to the outside edge. Remove the battery from its housing by lifting it up from the side closest to the outside edge.
手順 3  ¶
  • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
