メインコンテンツにスキップ
ヘルプ
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Heat Sink Replacement
  • 作成者: iRobot
  • 難易度: 難しい
The heat sink helps keep the processor cool and happy.
手順 1 Heat Sink  ¶
Remove the following 7 Phillips screws from the heat sink:
手順 1 Heat Sink  ¶
  • Remove the following 7 Phillips screws from the heat sink:
  • Four 4 mm silver screws.
  • Two 5 mm black screws.
  • One 9 mm silver screw in the upper left corner of the left fan.
手順 2  ¶
Remove the heat sink from the case, minding the left corner, as it tends to catch in the case (the fans will come out with the heat sink).
手順 2  ¶
  • Remove the heat sink from the case, minding the left corner, as it tends to catch in the case (the fans will come out with the heat sink).
手順 3  ¶
Remove the seven Phillips screws securing the fans to the heat sink.
手順 3  ¶
  • Remove the seven Phillips screws securing the fans to the heat sink.
  • Lift the fans out of the heat sink.
