メインコンテンツにスキップ
ヘルプ
PowerBook G4 Aluminum 15" 1.5-1.67 GHz Display Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
  • 作成者: iRobot
  • 難易度: 難しい
Change out the entire display assembly, including the inverter, Airport antennas, hinges and casing.
手順 1 Display  ¶
Remove the two 4.2 mm silver Phillips screws from either side of the large orange Airport ribbon.
手順 1 Display  ¶
  • Remove the two 4.2 mm silver Phillips screws from either side of the large orange Airport ribbon.
手順 2  ¶
Lift the Airport card out of the computer and slide a spudger between the card and the antenna connector to disconnect the cable from the card.
手順 2  ¶
  • Lift the Airport card out of the computer and slide a spudger between the card and the antenna connector to disconnect the cable from the card.
  • Deroute the antenna cable from the side of the card, removing tape as necessary.
  • You don't need to remove the Airport card entirely. We're just trying to free up the Airport antenna cable.
手順 3  ¶
Using a spudger, pry up the Bluetooth board from the cavity in front of the battery compartment.
手順 3  ¶
  • Using a spudger, pry up the Bluetooth board from the cavity in front of the battery compartment.
手順 4  ¶
Disconnect the Bluetooth antenna cable from the Bluetooth board.
手順 4  ¶
  • Disconnect the Bluetooth antenna cable from the Bluetooth board.
手順 5  ¶
Close the display and turn the hinge side of the computer to face you.
手順 5  ¶
  • Close the display and turn the hinge side of the computer to face you.
  • Remove the remaining Phillips screw on either side of the hinge (two screws total).
手順 6  ¶
Open the display and turn the computer so the screen faces you.
手順 6  ¶
  • Open the display and turn the computer so the screen faces you.
  • Remove the 10 mm T8 Torx screw closer to the display on either side of the hinge (two screws total).
  • When replacing the display, make sure that the right screw pins down the ground loop from the display data cable.
手順 7  ¶
Be sure to support the display with one hand while removing the final two screws.
手順 7  ¶
  • Be sure to support the display with one hand while removing the final two screws.
  • Remove the longer 13 mm shouldered T8 Torx screw remaining on either hinge (two screws total).
手順 8  ¶
Lift the display off.
手順 8  ¶
  • Lift the display off.
