メインコンテンツにスキップ
ヘルプ
Asus V6800V Fan Replacement
文法の修正
文法の修正
あなたの中にある日本語能力を呼び起こし、このガイドの文法に磨きをかけましょう。
箇条書き!
箇条書き!
マークアップやブレットの色や形を変えてコーディネートしてみるとこのガイドをより見やすくできます。
不明瞭なテキスト
不明瞭なテキスト
このガイドのテキストの数カ所が混乱し、重複しトピックから外れています。編集してより明確にしてください!
Cleaning and Replacing fan
セクション
ツール
手順 1 Fan  ¶
Remove highlighted screws, pry open case at highlighted spot. Remove highlighted screws, pry open case at highlighted spot.
手順 1 Fan  ¶
  • Remove highlighted screws, pry open case at highlighted spot.
手順 2  ¶
There are red, yellow, and black set of wires going to a white connector. Grab the three cables and pull straight up, away from the computer. Make sure not to pull wires from connector. White connector should pop off with very little force.
手順 2  ¶
  • There are red, yellow, and black set of wires going to a white connector. Grab the three cables and pull straight up, away from the computer.
  • Make sure not to pull wires from connector. White connector should pop off with very little force.
手順 3  ¶
Remove screws highlighted. Remove screws highlighted.
手順 3  ¶
  • Remove screws highlighted.
手順 4  ¶
Fan should come up very easily. Grab the set of wires that you disconnected earlier and pull straight up. In our pictured fan, there are a few pieces missing.
手順 4  ¶
  • Fan should come up very easily. Grab the set of wires that you disconnected earlier and pull straight up.
  • In our pictured fan, there are a few pieces missing.
手順 5  ¶
Use a cotton swab to remove dust. Also you can use compressed air, blow air from the inside out to clear dust from vent, or heat sink. Use a cotton swab to remove dust. Also you can use compressed air, blow air from the inside out to clear dust from vent, or heat sink.
手順 5  ¶
  • Use a cotton swab to remove dust. Also you can use compressed air, blow air from the inside out to clear dust from vent, or heat sink.
