メインコンテンツにスキップ
ヘルプ
Nintendo DSi XL Upper Case Replacement
Replacing the upper case.
Customize the color of your DSi XL by replacing the upper case.
手順 1 Upper Case  ¶
Remove the seven 2.5 mm silver screws securing the power board to the upper case. Lift the power board off the upper case.
手順 1 Upper Case  ¶
  • Remove the seven 2.5 mm silver screws securing the power board to the upper case.
  • Lift the power board off the upper case.
手順 2  ¶
Open the case slightly. Push the directional pad up through the upper case and remove it from the upper case.
手順 2  ¶
  • Open the case slightly.
  • Push the directional pad up through the upper case and remove it from the upper case.
  • Push the power button up through the upper case, and remove it from the upper case.
手順 3  ¶
Remove the LED diffuser and black retaining bracket by turning the upper case upside-down and letting both pieces fall into your hand. Remove the LED diffuser and black retaining bracket by turning the upper case upside-down and letting both pieces fall into your hand.
手順 3  ¶
  • Remove the LED diffuser and black retaining bracket by turning the upper case upside-down and letting both pieces fall into your hand.
手順 4  ¶
The front bezel is held in place by the clutch hinge on the left side of the DSi Xl=L. Using the tip of the spudger, push the clutch hinge to the left.
手順 4  ¶
  • The front bezel is held in place by the clutch hinge on the left side of the DSi Xl=L.
  • Using the tip of the spudger, push the clutch hinge to the left.
  • You will hear a "click" when the clutch has been completely displaced. Some force will be required.
手順 5  ¶
Lift the front bezel off of the upper case, tilting the left side of the front bezel away from the upper case first. Lift the front bezel off of the upper case, tilting the left side of the front bezel away from the upper case first.
手順 5  ¶
  • Lift the front bezel off of the upper case, tilting the left side of the front bezel away from the upper case first.
手順 6  ¶
Remove the hollow hinge pin from the right side of the DSi XL.
手順 6  ¶
  • Remove the hollow hinge pin from the right side of the DSi XL.
  • The upper case remains.
