メインコンテンツにスキップ
ヘルプ
MacBook Pro 17" Models A1151 A1212 A1229 and A1261 Right Fan Replacement
  • 作成者: iRobot
  • 難易度: 普通
Replacing a defective fan is pretty easy and will keep your laptop running cool.
手順 1 Right Fan  ¶
Disconnect the display data cable and right fan cable from the logic board. If you have a MacBook Pro 17" Model A1229 or A1212, the connectors have different compositions and are highlighted in the second picture.
手順 1 Right Fan  ¶
  • Disconnect the display data cable and right fan cable from the logic board.
  • If you have a MacBook Pro 17" Model A1229 or A1212, the connectors have different compositions and are highlighted in the second picture.
  • For models A1229 and/or A1212, carefully wedge the flat end of a spudger underneath the right fan cable to pry it up off its socket. Failure to do so may result in the whole socket coming off the motherboard instead of just the cable.
手順 2  ¶
Remove the three silver T6 Torx screws securing the right fan.
手順 2  ¶
  • Remove the three silver T6 Torx screws securing the right fan.
手順 3  ¶
Lift the right fan and its metal bracket out of the logic board.
手順 3  ¶
  • Lift the right fan and its metal bracket out of the logic board.
