メインコンテンツにスキップ
ヘルプ
Samsung Galaxy Tab 7.7 Headphone Jack Replacement
This guide will give you step by step instructions to replace the audio jack of your Samsung Galaxy Tab 7.7.
Use this guide to replace the audio jack when it either ceases to function, or is functioning incorrectly.
手順 1 Opening the tablet  ¶
Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet. Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
  • Insert the prying tool between the glass screen and the silver binding. Pry around the screen until the screen is separated from the back of the tablet.
手順 2 Disconnecting the audio jack  ¶
Detach the connector that connects the audio jack to the flex cable.
  • Detach the connector that connects the audio jack to the flex cable.
手順 3 Unscrewing the audio jack  ¶
Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
  • Use the Phillips #00 screwdriver to remove the 2 screws that secure the audio jack in place.
手順 4 Removing the audio jack  ¶
Pick up and remove the defective audio jack. Pick up and remove the defective audio jack.
  • Pick up and remove the defective audio jack.
