メインコンテンツにスキップ
ヘルプ
DualShock 3 Battery Replacement
おすすめのガイド
おすすめのガイド
このガイドはiFixitスタッフによって太鼓判が押されています。
Replace your DualShock 3's lithium battery.
Use this guide to replace the internal lithium battery inside PlayStation 3 controllers.
セクション
ツール
手順 1 Battery  ¶
Lift the battery off the motherboard for enough clearance to access the battery connector.
手順 1 Battery  ¶
  • Lift the battery off the motherboard for enough clearance to access the battery connector.
手順 2  ¶
Carefully pull the battery connector away from its socket on the motherboard.
手順 2  ¶
  • Carefully pull the battery connector away from its socket on the motherboard.
  • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
