メインコンテンツにスキップ
ヘルプ
Xbox 360 S Right Case Replacement
Right case replacement.
  • 作成者: Matthew Newsom
  • 所要時間: 30分 - 1時間
  • 難易度: 難しい
Make your Xbox look shiny and new by replacing the outer panels.
セクション
ツール
手順 1 Right Case  ¶
This is the terminal point if you ever want to send your Xbox back to Microsoft for repair.
手順 1 Right Case  ¶
  • This is the terminal point if you ever want to send your Xbox back to Microsoft for repair.
  • Remove the large white warranty sticker from the metal frame to expose a screw.
手順 2  ¶
Remove the five 55.5 mm T10 Torx screws securing the right case to the metal frame.
手順 2  ¶
  • Remove the five 55.5 mm T10 Torx screws securing the right case to the metal frame.
手順 3  ¶
Turn the Xbox over so the right case is facing up.
手順 3  ¶
  • Turn the Xbox over so the right case is facing up.
  • Lift the right case off by its metal framework.
