メインコンテンツにスキップ
ヘルプ
Canon EOS 5D Mark II Back Panel Replacement
This guide will show users how to remove the back panel.
  • 作成者: Mike Seed
  • 所要時間: 5 - 15 分
  • 難易度: 普通
Use this guide to remove the back panel in order to access the LCD, buttons, speaker, and other parts.
セクション
ツール
手順 1 Back Panel  ¶
Peel back the rubber cover above the in/out ports to reveal two screw heads.
手順 1 Back Panel  ¶
  • Peel back the rubber cover above the in/out ports to reveal two screw heads.
手順 2  ¶
Remove both 5.4 mm screws using a Phillips #0.
手順 2  ¶
  • Remove both 5.4 mm screws using a Phillips #0.
手順 3  ¶
Lift the in/out port plastic covering from the bottom where the backup battery used to be.
手順 3  ¶
  • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
手順 4  ¶
Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
手順 4  ¶
  • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
手順 5  ¶
Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
手順 5  ¶
  • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
手順 6  ¶
Peel back the rubber covering next to the menu dial to access the screw.
手順 6  ¶
  • Peel back the rubber covering next to the menu dial to access the screw.
  • Remove the single 3.4 mm screw using a Phillips #0.
手順 7  ¶
The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
手順 7  ¶
  • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
手順 8  ¶
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
手順 8  ¶
  • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
  • The back panel is now free from the rest of the device.
