メインコンテンツにスキップ
ヘルプ
Mac Mini Mid 2010 Bottom Cover Replacement
Removing the bottom cover.
  • 作成者: Andrew Bookholt
  • 所要時間: 15 秒 - 2分
  • 難易度: とても簡単
Remove the bottom cover to access components inside your Mac mini Model A1347.
手順 1 Bottom Cover  ¶
Place your thumbs in the depressions cut into the bottom cover. Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
手順 1 Bottom Cover  ¶
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
手順 2  ¶
Tilt the mini enough to allow the bottom cover to fall away from the outer case.
手順 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
