メインコンテンツにスキップ
ヘルプ
Panasonic SC-PM31 Back Panel Replacement
Use this guide to learn how to remove and replace the back panel of the SC-PM31.
  • 作成者: Michael Ebert
  • 所要時間: 10分
  • 難易度: とても簡単
This replacement guide involves removing many screws. Before you start to take apart the device, you will need a #2 Phillips screwdriver and plastic opening tools. Also make sure you have the replacement back panel on hand.
手順 1 Removing the back panel screws  ¶
Remove the eight 9.5 mm #2 Phillips screws attaching the back to the device.
  • Remove the eight 9.5 mm #2 Phillips screws attaching the back to the device.
手順 2 Removing the back panel  ¶
With a gentle tug, unplug the red and black cable from the tan circuit board. Using both hands, unlock the plastic back panel from the metal clasps (located on the sides of the unit) by pulling the plastic away from the metal. Focus on undoing first one clasp, then the other. Slide the back panel toward you and off of the unit.
  • With a gentle tug, unplug the red and black cable from the tan circuit board.
  • Using both hands, unlock the plastic back panel from the metal clasps (located on the sides of the unit) by pulling the plastic away from the metal. Focus on undoing first one clasp, then the other.
  • Slide the back panel toward you and off of the unit.
