メインコンテンツにスキップ
ヘルプ
MacBook Pro 15" Unibody Mid 2010 Left Fan Replacement
Replace the left fan in your Mid 2010 MacBook Pro 15" Unibody.
  • 作成者: Walter Galan
  • 所要時間: 20分
  • 難易度: 普通
Replace a faulty fan to keep temperatures down.
手順 1 Left Fan  ¶
Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
手順 1 Left Fan  ¶
  • Remove the three 3.4 mm T6 Torx screws securing the left fan to the logic board.
  • In some models, these T6 Torx screws may be 3.1 mm long.
手順 2  ¶
Use the flat end of a spudger to disconnect the left fan connector from the logic board. It is useful to twist the spudger axially from beneath the fan cable wires to release the connector. The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
手順 2  ¶
  • Use the flat end of a spudger to disconnect the left fan connector from the logic board.
  • It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
  • The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
手順 3  ¶
Lift the left fan out of the upper case.
手順 3  ¶
  • Lift the left fan out of the upper case.
