メインコンテンツにスキップ
ヘルプ
Panasonic PV-GS9 LCD panel replacement
続きが抜けています
続きが抜けています
このガイドはどのようにしてプロセスを始めるかの情報が抜けています。必要条件ガイドを作成しましょう!
手順の記述もれ
手順の記述もれ
申し訳ございませんがこのガイドは、いくつかの重要なステップが不足しています。
Remove the side panel containing LCD on the camcorder.
  • 作成者: Nate Chamness
  • 所要時間: 20分
  • 難易度: 普通
This guide shows how to remove the side panel containing the LCD viewing screen and speakers to gain access to other parts of the camera.
手順 1 LCD Panel Removal  ¶
Remove the indicated 4.5mm screws from the LCD side of the camera. Remove the indicated 4.5mm screws from the LCD side of the camera.
  • Remove the indicated 4.5mm screws from the LCD side of the camera.
手順 2  ¶
Place a plastic opening tool under the bottom of the blue panel beneath the camcorder. Using two tools may be useful, if difficult. Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
手順 2  ¶
  • Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
  • Using two tools may be useful, if difficult.
  • Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
  • Remove the panel from the camcorder.
手順 3  ¶
Before removing the LCD panel from the camcorder, disconnect the ribbon cables joining the LCD panel to the logic board. There may be multiple ribbon cables attached to the same point on the logic board. There may be multiple ribbon cables attached to the same point on the logic board.
手順 3  ¶
  • Before removing the LCD panel from the camcorder, disconnect the ribbon cables joining the LCD panel to the logic board.
  • There may be multiple ribbon cables attached to the same point on the logic board.
