メインコンテンツにスキップ
ヘルプ
IBM ThinkPad T42 Optical Drive Replacement
続きが抜けています
続きが抜けています
このガイドはどのようにしてプロセスを始めるかの情報が抜けています。必要条件ガイドを作成しましょう!
  • 作成者: Gerald Watanabe
  • 所要時間: 1 - 2 分
  • 難易度: とても簡単
Removing the optical drive is extremely easy and will only a take a minute.
手順 1 Screw Removal  ¶
Remove the single screw holding the optical drive on the underside of the laptop
  • Remove the single screw holding the optical drive on the underside of the laptop
手順 2 Unlock Switch  ¶
Push the small slider to unlock position, a tab will automatically pop out.
  • Push the small slider to unlock position, a tab will automatically pop out.
手順 3 Drive Removal  ¶
Pull the tab to dislodge the optical drive, then carefully pull the drive out.
  • Pull the tab to dislodge the optical drive, then carefully pull the drive out.
