メインコンテンツにスキップ
ヘルプ
MacBook Unibody Model A1342 Clutch Cover Replacement
Replace a damaged clutch cover.
Remove the clutch cover to access cables terminating inside the display.
セクション
手順 1 Clutch Cover  ¶
Remove the two 3 mm Phillips screws securing the clutch cover to the rear display bezel.
手順 1 Clutch Cover  ¶
  • Remove the two 3 mm Phillips screws securing the clutch cover to the rear display bezel.
手順 2  ¶
Insert the flat end of a spudger into the open end of the clutch cover and pry up to release it from the rear display bezel. Pry up from both sides of the clutch cover until it is completely free from the display assembly. Pry up from both sides of the clutch cover until it is completely free from the display assembly.
手順 2  ¶
  • Insert the flat end of a spudger into the open end of the clutch cover and pry up to release it from the rear display bezel.
  • Pry up from both sides of the clutch cover until it is completely free from the display assembly.
手順 3  ¶
Remove the clutch cover from the display assembly.
手順 3  ¶
  • Remove the clutch cover from the display assembly.
