メインコンテンツにスキップ
ヘルプ
Olympus D590 LCD screen Replacement
アクションショット
アクションショット
アクションヒーローになりましょう!このガイドはある特定の動作をどのように行なうのか、より詳細な画像が必要です。
不適切なツール
不適切なツール
画像と/やテキスト中に正しい工具を使用することでこのガイドがより良くなります。
高画質の画像が必要
高画質の画像が必要
よりよい画像があればこのガイドが改善されます。よければ新しい写真を撮影し、編集し、アップロードしてお手伝いください。
文法の修正
文法の修正
あなたの中にある日本語能力を呼び起こし、このガイドの文法に磨きをかけましょう。
  • 作成者: Sara
  • 所要時間: 30分
  • 難易度: 難しい
This guide will give step-by-step instructions on how to install a LCD screen in a Olympus D590 camera.
セクション
手順 1 LCD screen  ¶
Unscrew the screw shown in the picture from LCD screen.
手順 1 LCD screen  ¶
  • Unscrew the screw shown in the picture from LCD screen.
手順 2  ¶
Remove the side pannel by sliding it off the body of the camera. Lift the camera no more than 3cm to make sure all screws have been taken off.
手順 2  ¶
  • Remove the side pannel by sliding it off the body of the camera.
  • Lift the camera no more than 3cm to make sure all screws have been taken off.
手順 3  ¶
Flip camera so you are looking at the front. Remove gray and blue wiring with tweasers by gently wiggling and pulling.
手順 3  ¶
  • Flip camera so you are looking at the front.
  • Remove gray and blue wiring with tweasers by gently wiggling and pulling.
  • Be careful not to rip the wiring tape with the tweezers.
手順 4  ¶
Locate the tape securing the wiring with the gray end piece located on top of the camera. Gently lift up on the tape till all wires are exposed.
手順 4  ¶
  • Locate the tape securing the wiring with the gray end piece located on top of the camera.
  • Gently lift up on the tape till all wires are exposed.
手順 5  ¶
Flip Camera to the bottom side as shown.
手順 5  ¶
  • Flip Camera to the bottom side as shown.
  • Pull and wriggle the thin yellow wiring tape to detach it from the rest of the camera, while leaving it attached to the LCD screen.
手順 6  ¶
Flip camera so the front is facing you. Locate speaker in upper right hand corner. Gently lift with tweasers.
手順 6  ¶
  • Flip camera so the front is facing you.
  • Locate speaker in upper right hand corner.
  • Gently lift with tweasers.
  • Feed wiring through designated spot so that it is no longer connected to the camera.
手順 7  ¶
Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera. Gently pull the thick yellow wiring out by using the forefinger and thumb.
手順 7  ¶
  • Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera.
  • Gently pull the thick yellow wiring out by using the forefinger and thumb.
